Hi everyone! :)
A few days ago, my 92 Sable (3.8L) suddenly seems to have lost a lot of power when I step on the gas. It seems like it would be a spark plug issue, but they all seemed to be in good condition when I took the front 3 out. The engine and transmission are both about a year or so old, so I doubt it is anything serious. To better describe my problem, when I hit the gas, the rpm's are quite normal, but the car doesn't accelerate like it usually does and seems like it doesnt want to shift into the next gear. When I rev it really high, the engine makes a noise something like air being let out somewhere that it shouldn't. Almost like a strong hissing. *EDIT* After about 5 minutes of driving, the 'Check Engine' light comes on.*/EDIT* I have taken a couple of pictures that I would like to have opinions on. I have identified two things that I think may be part of the problem. I have an old cracked hose that seems to limit air suction into the small pipe that it is attached to. I plan to replace the hose tomorrow to remedy the problem. However, a small grey plastic block (not sure what it is) seems to have melted on the underside and looks kind of burnt on the inside. Please take a look at the pictures and try to explain to me what those 2 parts do and if they might be the reason for my problems.
Note: Also, I forgot to mention that I painted the car recently and was wondering if maybe some primer/paint/clear may have somehow got into the works. I kind of doubt it, but it occurred to me that it may be an issue. Thanks.
http://evan.nour.ca/sable/area.jpg' alt='' width='1024' height='768' class='attach' />[/url]
[url=http://evan.nour.ca/sable/101_0168.JPG][img]http://evan.nour.ca/sable/101_0168.JPG' alt='' width='1024' height='768' class='attach' />[/url]
[url=http://evan.nour.ca/sable/101_0169.JPG][img]http://evan.nour.ca/sable/101_0169.JPG' alt='' width='1024' height='768' class='attach' />[/url]
[url=http://evan.nour.ca/sable/101_0170.JPG][img]http://evan.nour.ca/sable/101_0170.JPG' alt='' width='1024' height='768' class='attach' />[/url]
[url=http://evan.nour.ca/sable/101_0171.JPG][img]http://evan.nour.ca/sable/101_0171.JPG' alt='' width='1024' height='768' class='attach' />[/url]
G
That same sensor exploded/melted on me too... Find a replacement.. If you're in the Los Angeles area I can just give you one..
and maybe replace your TPS sensor aswell..
So what is my little melted sensor responsible for? would it have any impact on the problems that I am having? I dont live in the LA area, so I cant stop by to get one, but thanks for the offer :) What is my tps sensor? can you point it out to me on one of my pictures? thanks
Originally posted by Firespirit@Aug 3 2004, 08:52 AM
And Clean that engine bay!!!! You're gunna give Jeremy (n2space) the big heartattack!
I clean the bay every 3 months. If it is too dirty I am kind of embarrassed to have a mechanic look at it. The Technician at my dealer service department commented how clean my engine is.
Originally posted by Evan+Aug 3 2004, 11:01 AM--><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Evan @ Aug 3 2004, 11:01 AM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin-SHO Continental@Aug 3 2004, 02:54 AM
So what is my little melted sensor responsible for? would it have any impact on the problems that I am having? I dont live in the LA area, so I cant stop by to get one, but thanks for the offer :) What is my tps sensor? can you point it out to me on one of my pictures? thanks[/b][/quote]
TPS - Throttle Position Sensor
Can't help you much more then that since i don't have a 3.8 and i don't know where the TPS is or what sensor that is of your that exploded on you for that matter. But i'm sure another 3.8 owner will help you out shortly.
