ok...I was just wondering about the tranny issues....I want to change the fluid ASAP....what kind should I use? also should I use Full syn? again what kind....also should I change the filter? I am not even sure if it has one...lol...thanks in advance...Garth
you can only use Mercon V, and full synthetic is best, and change the filter.
great! is there a brand you would recommend? and again sorry for the questions...but is just dropping the pan sufficient? or do I need to pump the fluid out? I have in the past disconnected a tranny line at the radiator and pumped it out that way...;) Garth
<div class='quotemain'>
Check the Wiki on this site... There is a great article about changing the fluid/filter!
will do thanks!!
I used Hurst Hot shift in my Taurus and install a tranny cooler as soon as you can. Both will help.
Have a good one
Bob
