Is there a harness adapter that plugs into the woofer outs on the amp that turn into RCA preout for an aftermarket amp? Simialr to this:
The JBL sub outputs are already at preamp level. Two of the 4 pins are 12 volt power to the JBL sub's amp. You could conceivably solder on your own RCA's to an aftermarket amp, using the 12 volt as a remote turn-on signal for the amp.
I already knew they were at pre out levels. I have though of creating my own and I am searching for that elusive harness. Do you happen to know what the wires are? I have also had the idea of just soldering directly from the amp without the harness but don't know what each pin is for.
I would keep the RCU end stock with its plug and mod the other end, if anything. I will research it on my 96 and get back to you.
-Dan
Thanks. It would be great mod.
