people have done it and say it works so I would say go for it. Only thing I would change would be to leave the tips out of it, a little too ricey for me.
Not necessarily.Originally posted by 93taurusSX@Apr 17 2004, 05:43 PM
From a purely performance standpoint, straight through, free flowing mufflers are better than Flowmasters. The flows use a series of baffles that will impede the path of the exhaust gas, instead of insulation material wrapped around a mesh pipe.
Speaking from the SHO perspective, any muffler changes are only for the "sound" factor, and not because a n/a SHO will show any noticeable gain (nor really any gain on the dyno, for that matter.......less than 5 HP is within the range of testing error)).Originally posted by 97GreenStreak3.0@Apr 17 2004, 06:11 PM
My SHO had "glasspack mufflers", basically straightpipes, put in by the previous owner. Would you then suggest taking them out and having some sort of actual muffler welded on?
Sorry for the hijacked thread![]()
Are you telling me that the stock manifold exhaust headers are not a restriction??? And that Cats aren't either???? allowing the air to flow better through the exhaust definately has a performance effect on the engine.Originally posted by Ron Porter@Apr 17 2004, 04:00 PM
In any case, the cat is not a performance impediment. In fact, on a basically stock motor, the whole exhaust system is not a real impediment. Mufflers are changed (for SHO folks) primarily for the sound factor, and the performance gain (if any) is negligible.
In speaking of SHOs, no, the stock exhaust manifolds are NOT an impediment, nor are the cats. The cats aren't an impediment in virtually every engine out there.Originally posted by silvapain+Apr 18 2004, 01:38 PM-->QUOTE (silvapain @ Apr 18 2004, 01:38 PM)<!--QuoteBegin-Ron PorterAre you telling me that the stock manifold exhaust headers are not a restriction??? And that Cats aren't either???? allowing the air to flow better through the exhaust definately has a performance effect on the engine.@Apr 17 2004, 04:00 PM
Cats restrict flow alot, but I would not remove them. Plus, don't the duratecs have 3 cats, or is that just the SHO's? I know that the vulcans have two. [/b]
most definitly true... look at magnaflows or dynomax mufflers. they are cheaper(i think), they sound better IMO, and they flow lots more air than a flowmaster.Originally posted by 93taurusSX@Apr 17 2004, 06:43 PM
No they don't. Stock duratec shift points are just under 6kRPM, IIRC SHO's rev up to 7k or 7500RPM.Originally posted by silvapain@Apr 19 2004, 09:46 AM
1. Duratecs have just as much RPM range as the SHO does.
Yes, the SHO power peak is at 6K, with redline at 7K. It's been awhile since I drove a Duratec, but I don't believe it was anywhere near that high. The current Duratec peaks at 5,500.Originally posted by mikehawk+Apr 19 2004, 05:31 PM-->QUOTE (mikehawk @ Apr 19 2004, 05:31 PM)<!--QuoteBegin-silvapainNo they don't. Stock duratec shift points are just under 6kRPM, IIRC SHO's rev up to 7k or 7500RPM. [/b]@Apr 19 2004, 09:46 AM
good idea, these guys didnt do anything but argue. I don't know much about exhaust, but I do know that there is very little HP gain if any. I say that if you want to get these mufflers or take of your cat or do what ever you want, the you don't take these guy's advise. I suggest you go out and do what ever you want to do, because it's your car, and you're the one who's got the final say. Who cares what all these other people think? If it's cool to you, and you like it, despite the non-existant HP gains, then go for it.Originally posted by jorsh@Apr 19 2004, 09:24 PM
im trying to get the best setup and after reading i think i will just go a high flow cat, new mufflers(not sure where from yet) and some chrome pipes.
My vulcan gets higher than that.Originally posted by Ron Porter+Apr 19 2004, 07:36 PM-->QUOTE (Ron Porter @ Apr 19 2004, 07:36 PM)Originally posted by [email protected] 19 2004, 05:31 PM
<!--QuoteBegin-silvapainYes, the SHO power peak is at 6K, with redline at 7K. It's been awhile since I drove a Duratec, but I don't believe it was anywhere near that high. The current Duratec peaks at 5,500. [/b]@Apr 19 2004, 09:46 AM
Not really what it can wind, it's the power at the elevated rpms. On the current model, the Duratec peaks 200 HP @ 5,500, with the 207 torque peak @ 4,500. The other 3.0 engines (std @ FFV) have the power peak of 153 @ 5,000, and the torque peak of 186 down @ 3,250.Originally posted by silvapain+Apr 19 2004, 11:21 PM-->QUOTE (silvapain @ Apr 19 2004, 11:21 PM)Originally posted by Ron [email protected] 19 2004, 07:36 PM
<!--QuoteBegin-silvapainMy vulcan gets higher than that. [/b]@Apr 19 2004, 09:46 AM
