I’m replacing the oil pan and gasket on my 03 taurus 3.0. I have my torque wrench set a tad low at 105 inch lbs. this feels like a lot of torque for an oil pan. I put this torque on a bolt on the body and bent the washer before it clicked off. Is it really that much torque or is my wrench not clicking off right?
Yes, that's the specified torque for oil pan bolts. Yes, it seems high for the application. 80 in/lbs would be sufficient, but use your own discretion. I am a certified master mechanic for 42 yrs. At G.M. we spec 9NM for a bolt this size (80 in/lbs)
Well, 108 in/lbs would be 9ft/lbs, So that seems about right. Hard part about torquing this light is making sure to feel the click on the inch/pound torque wrench. Very subtle.
I’m familiar with the tools. I had that issue on a larger torque wrench where I couldn’t feel the click, but it was clicking off. This one is a 1/4 drive torque wrench. The click is nice and prominent, but I’m bending a washer before it clicks.
I typically use the ol “calibrated wrist” for some pans. The person before me had the pan all bent up before from over torque. So I wanted to make sure I had the proper torque. I had to straighten it out and eventually get a new pan. That’s the one I have in now. It just kind of threw me off when I went to test the click on the body and it bent the washer before clicking off. 80 in/lbs sounds like a much more reasonable torque. If my wrench is right, 120 in/lbs is pretty high for pan bolts.
