1 - 9 of 9 Posts
hi i have a 1996 ford taurus gl and it doesnt have a key fob and i was wondering is it supposed to have one? any help on this topic would be appreciated
you can enter "FOB Programming" by cycling your ignition switch.
insert key and QUICKLY move from OFF To RUN (not START)8 times. Ending in RUN . The doors will then lock then unlock.
Also all does must be Closed.
If so, you have keyless entry. Congratulations. Go a buy a fob on eBay.
Most people don't get it on the first few tries. Don't get discouraged if you don't get it the first time.
Each time Completly with draw the key and wait a few seconds before tying again.
Welcome to the forum BTW. :welcome:
QUOTE (1996taurusgl @ May 26 2009, 01:04 PM) index.php?act=findpost&pid=728023
hi i have a 1996 ford taurus gl and it doesnt have a key fob and i was wondering is it supposed to have one? any help on this topic would be appreciated[/b]
Step 1. Find the instructions for programming a key fob
Step 2. If the lock "actuates" at the end of the instructions, then go buy one and use it. Get the right one (lock, unlock, panic, and trunk labeled on it)
QUOTE (thesavo @ May 26 2009, 01:43 PM) index.php?act=findpost&pid=728028
Welcome to the forum BTW. :welcome:[/b]
The instructions are a bit different for the early G3s.
http://www.taurusclub.com/encyclopedia/Features/Remote.html Find your year and corresponding instructions and try 'er out.
QUOTE (Bull Geek @ May 26 2009, 05:46 PM) index.php?act=findpost&pid=728068
No way! Never thought it varied. Guess I never thought of check the Encyclopedia. Wow. Some you need to jumper a connector to enter programming. Some had 5 Cycles then they switched to 8. Now newer models can be done with the service computer. Nice Fine!
QUOTE (thesavo @ May 27 2009, 09:46 AM) index.php?act=findpost&pid=728255
I have a '97 and all I did was use the 5 cycle method then hit 'unlock' on the remote -- its worked great ever since.
1 - 9 of 9 Posts
