· Premium Member
My wife's 2000 Taurus is coming up on it's second tranny service. The last time at 40k I had it flushed. This time I am planning on getting it flushed, then dropping pan to change filter/ clean pan & magnets. I was thinking of adding Mobil 1 to replace what is lost with the pan drop.
Is Mobil 1 compatible with the Mercon/Ford fluid?
How much fluid is needed for replacing what is lost with pan drop?
Think of any problems of having some M1 and mostly regular stuff?
Thanks
· Premium Member
I don't know if it's compatible, but you shouldn't mix Mercon/Dexron III with Mercon V. If you do you'll end up with a shuddering in the shifting and could lead to premature tranny failure.
I also think it holds about 12-14 quarts of tranny fluid.
· Premium Member
That page does not mention mercon III, nor does it mention mercon V. I simply lists it as Ford Mercon performance levals compatable. Your best bet is to contact Mobil 1 directly to find out for sure.
· Registered
its not necessary to go with Mobil one atf. Go for something like valvoline mercon/dexron III....
changing ATF more frequently, and adding a tranny cooler is a better option than going for expensive Mobil1, amsoil etc...
