Originally posted by Critch@Jan 15 2004, 10:50 AM
Hey, wife just called, she has the brake, air bag, IP indicator, no wipers or heater, no speedometer. Is this one fuse or am I screwed big time with a electrical issue.
yeah, look at the fuse AND circuit. If it a MASS amount of things are out, the fuses or Circuit breakers is overloaded or blown.
If it was JUST your wipers or JUST your heater, then i wouldn't suspect the fuses, but since it is affecting more than ONE component, I would suspect FUSES and/or CIRCUIT BREAKERS
had this problem once when all the radio units, power door locks, power windows, digital clocks went out....turns out the fuse blew.
if it not the fuses, well then.....you have bad news.
