My 96 Sable has developed the following problem. Most of the time, when putting on the right turn signal, it gives the fast clicking sound with no signal showing in front or back. Sometimes it works normally. If you hold the lever a little short of fully "pushed up," the signal works fine. It also seems to work fine if in addition to pushing it upward you also push it forward a little bit. So it seems like the problem is in the lever arm or some switch as opposed to a lamp or fuse.
I am not very handy, but would be willing to attempt a relatively simple replacement. Any thoughts about what this problem is, and the difficulty of fixing it myself?
Thanks
George
Thanks
George
