The Tauri have been running well and I haven't been on the board for a while.
2004 3.0 Vulcan 217k
The warnings on the attached picture started after a 2 - hour trip.
They come and go, sometimes no warnings, other times display as show.n in picture
Brakes seem to be working normally..
Also, it's been a while since I serviced the brakes so I will probably have to go through everything.
Has anyone else seen this combination of three warnings and can point me in the right direction to resolve this.
All advice appreciated, John Kenneth
I had this on '03 Sable. Was the electronics part of the ABS module. I got a module from JY and switched it out. In the pic "TCS" means it is for "traction control" option.
You can remove the module and still drive the car. Pic of old one and JY part. Four years ago and still working fine. Tedious project to exchange.
I agree with chartmaker. You need to check your system soon. Is there any codes? If you do not have a tester, then go to a Auto Zone, Advance, whatever and get them read. If it is a ABS system problem, I have a step by step write up with photos on how to remove the ABS Electronics and what/where to send them. Just email me at [email protected]. I will send a copy to you.
From experience:
Red light only, low brake fluid, or parking brake not off or switch issue on parking brake.
Amber ABS only, wheel sensor.
Both, the module failed.
My pic of tools home made assembly made it less of a pain to reach the 6 screws. Do drop a screw. They are special.
True, also my 2000 Owner's Manual gives three possibilities for the Brake Light being on. Apart from parking brake and fluid level, the third one is:
Brake force distribution system failure. The ABS light will also illuminate if this condition is present.
And of course it says to seek service immediately :) .
I sent the module to an ABS module repair specialist when I had this issue.This was about 4 years ago.
I think it is risky to go for junkyard ABS modules at this point. I got a junkyard unit, and it was defective as well, though I kept it as a sort of "placeholder" while I sent the old original unit for repair.
