I have had my 2001 for about 10 months. For the second time since I have owned it, when activating the left turn signal, the indicator on the dash started flashing about twice as fast as it should be. The first time I noticed this I also noticed that the left rear brake light was not lighting. Before I could replace a bulb. The problem stopped. It start this again last Friday and did it for about a day and a half before.....you guessed it...it stopped.
Any Ideas?
Thanks in advance,
Bob
It's the bulb. It's quite possible that the broken filament is touching the other non-broken filament completing the circuit making it work and then they stop touching causing it to break the circuit.
