intermintent a/c heater blower 2001 sel
its strange had the car 2 days now sometimes the blower comes on fine other times it wont come at all or untill i hit a bump in a road or open and close glove box hard
i have the climate controll system i tried all setting auto on off...
the a/c is on but blower wont run also tried with heater at 70degrees no blower hit a bump and then it comes on.
any ideas ?
very low milage car
J
Guest
Not sure how likely it is, but it could be something dumb like a loose fuse (or one going bad). Might want to check your fues boxes to see if that's all it is. :)
Welcome to the club! B)
Do a self test on the EATC system:
1. Hold Off and Floor
2. Release them and within 2 seconds hit Auto
3. You will see a small spinning thing or a blank screen for about 30-45 seconds
4. If there are no codes, you will see 888 or all the segments on
5. If there are the code will be displayed
6. To reset, press the cooler button, to reset and clear and codes, hit the front defrost button.
Do this and let us know.
brought it to dealer it was blower they will replace have to order they said it was the brushes.
under warranty so no charge
thank you to every one with their info
Bad brushes on a 2001??
Wow, that must have been a defect, unless they let the thing run for 3 years straight.
On of the springs pushing the brushes towards it's contact point must have broken I'd say
