My taurus has the leather package and the interior door panels are peeling off of the doors. There is no way that i have found to re glue this because the backing just peel away again. Has anybody else had this problem, is there a recall, or someway to repair it. Thanks.
Premium Supporter
I'm guessing it's a gen 4 because my gen 4 with leather had the leather door panels.
Anyway...I belive it is vinyl. So pick up some vinyl glue and try again. I can't believe it's peeling off! Mine looked like you couldn't have peeled it if you tried. It was on there real tight. That sucks!
3M makes an adhesive called "Industrial 90" that comes in a spray can. This stuff is mega-strong and would be perfect to bond leather back to the panel. It's about $7.99 for a can and can be found at a Lowe's or Home Depot-type store.
Sometimes before regluing it is a good idea to remove the old glue or stickyback. I use mineral spirits or sometimes alcohol. Then you have a nice clean surface to spread or spray your new glue and it works better imho.
