I have had a problem of the intake manifold moaning for about a month now on cold startups. It sounds like the noise you can make blowing through a Shop Vac hose, low and deep moaning. It lasts longer the colder the temperature is outside and stops almost instantly after about five to ten minutes. I pulled the filter cover and the sound got ten times loader so I know it is coming from the intake. I have never heard a sound like this and know it is not a mechanical sound but an air flow resonance sound. I did try to use Sea Foam spray to clean the manifold before the noise because I was getting a popping noise one time before the moaning sound. The popping sound was after a 20 mile trip. It stopped and now moaning.
I am starting to think it is related to the runner control in the 2006 manifolds but don't know enough about the way it works. I did remove a vacuum hose by the runner controller and sprayed Sea Foam in to try to clean that side of the manifold. I will see if this works on the next cold start. THERE ARE NO ENGINE CODES.
Does any one have info on the intake and how the runner system works and when it switches.
