I'm getting ready to install a alpine 7892 deck and integrate into my mach stereo system, and electronic A/C controls.. Using the method on brads old project sho, other than running new cables from the wiring harness to all the speakers, what else will I need to know.. I'm expecting roughly a 2 to 4 hour install time.. Mainly for running the new cables.. Does this sound good,
If anybody has a diagram of anything that I havn't set out plz post..
Thx,
Speedy..
You're going to need to tap into power, constant, and ground lines to power your deck. You're also going to need to run an antenna adapter to trunk. I would bump that time up to 4 hours minimum of work too.
The power and ground are no problem, but the constant might be a b!tch. Make sure you tap into the correct ignition wire!
JR
well this is not nessasary because my car doesn't quite have an antenna, so I was going to get XM and just plug the back hole that has been there for who knows how long..
where would I find the constant around...cause I was just going to unplug the wires from the back of the existing radio.. Well anywho, I will figure it out when I get my fiber all made..
Fiber? If I get a chance this weekend, I'll pull off my radio and check which wire the constant is. I'll try to get it done saturday.
JR
Even better, but I thought I'd mention that just in case.
Use a dmm and test the wires in the harness, but I believe the constant is red and yellow IIRC, don't quote me on that tho.
Yellow is usually the aftermarket standard for constant, as red is + and black is -. Ford, however, doesn't always stick to standards, as is the case with trans pans being reused on different transmissions. It's probably a striped wire.
JR
