Installing a 2,000 watt inverter?
270 Views 6 Replies 5 Participants Last post by  MEADOWFERN
I was hoping to buy an suv, but the piggy bank is saying now :( I have some property and need to do maintenance from time to time - also go camping. i would like to install a power inverter in the Taurus - ideally a 2,000 watt inverter. Has anyone done this? Would I need to install a 200 amp alternator? I wish there were room under the hood for a 2nd battery.
I used a 2000 watt inverter back in 2003 during a blackout to power a small seven cubic foot chest freezer. I used the spring clamp leads and didn't need to run the engine all the time. With larger loads it would trip on under voltage so I needed to run the engine. I figure at idle you can get 40 to 60 amps from the alternator so figure 500 watts constant power without draining battery.
  • Like
Reactions: 1
So if I really wanted 2,000 watts I would need a 250 amp or more? I would not see myself needing that very often but I would like to have the potential.
For how long would you need 2000 watts? If it is for 15 or so minutes every hour, then a primary or secondary trunk AGM battery might be a better use of funds than changing the alternator.
  • Like
Reactions: 1
Car Alt are rated amps at 6000 rpm and 72F at core temperature. Goes downhill from there.
Buying a 2000 watt inverter generator is the best choice if you need that amount of power. It would be cheaper and more logical than wasting the car's engine life.
  • Like
Reactions: 2
I'd just get a mini 2000 generator. I bought one at Harbor Freight years ago for $325. Great off the grid or during power outs.
  • Like
Reactions: 2
