Hi, I was replacing my outer tie rod ends today, and while trying to turn the jam nut, I noticed that the inner tie rod turned. I assumed it was not supposed to turn. I had a wrench on the jam nut, and a wrench on the tie rod end - but nothing on the inner tie rod.
I haven't changed an inner tie rod before, but I read about a pin/rivet/nut back there, and so I wonder, did i break something? or simply loosen something that can be tightened back up? or is it ok that the inner tie rod end spins?
Thanks,
Mike
Thanks,
Mike
