Hi friends. Im sure people have asked about this before, but I wouldnt know where to look, so I started a topic.
The next mod I want to get is a superchip or performance chip of some kind. At the time I get the chip, I would also like to do larger injectors and fuel pump. I saw somewhere that the FFV motors (i have an ffv motor) have larger injectors than the regular vulcans. It said I had 23.5 lb/hr injectors. I really have no way of knowing if this is true or not, but if it is, then couldnt I just stick with those injectors and utilize the increased amount of fuel the chip will send without changing injectors? Now, if my car doesnt have the larger injectors, what size injectors would you recommend? Where might I find them from? What fuel pump should I use? Thanks for all of your help.
