So... new injector o-rings and a new attempt at putting them in. One still leaks. I investigated buying a fuel rail --- but nobody sells them. I assume this means that they're rarely the problem. So ... then... it must be the injector itself leaking? It literally showers forth when the key is turned.
It's going to take a day to order the new injector (no stock) ... so I'm on hold until then.
check to make sure the O ring didn't roll out of position. lube the o ring with oil to help everything slide.
and double check the fuel rail is bolted down correctly.
