:angryfire:
Alright so I finally move my new kenwood hu to under the eatc
Now the drivers side rear speaker has stopped working
I have that speaker hooked up to a 2 channle amp
I tried disconnecting and reconnecting the rca and tried switching the rca with each other
I checked all the connections into the amp
Could this be a blown speaker or would a blown speaker actually make some kind of noise, because mine makes noo sound what so ever
Should I try connecting it directly up to the head unit with out the amp??
What do you guys think
Spend my 02¢ wisely...
I would hook a speaker directly to the amp and see if it works. If doesn't, your problem is the amp. If it does, pull the rear speaker and hook another one up to the speaker leads and see if it works. If it doesn't, you've got a speaker wire issue. If it does, your speaker's shot.
alright figured out the problem
the amp doesnt work properly...only one channel works...so i ahve both speakers running off the one channel for right now
