Ok, you know how when you take your car in, the mechanics are bound to find something wrong? Yeah, well that's what happened.
I planned to take my car in last Thursday to get the alignment done. Well, they (an independent garage, not the dealership) had my car for an hour and said that the passenger side tie-rod was bad. They charged me $28 to look at it and gave the car back to me. Well I thought about it over the weekend and I've seen what happens when a tie-rod breaks and it's not pretty. So I make appointment for Friday (yesterday).
So I take the car in again to get the tie-rod done at around 10 AM. They said it would probably be $220 for the tie-rod and alignment and it would be done at around 1:30 PM. So I go home and do some other stuff. They call me at around 2 PM to ask me if I want to do the camber. I'm like, "Isn't that part of the alignment?" and they're like, "We might need to order special shims and it'd probably add $100 to the total." Then I freak out and tell them just to do the toe. Then about 15 minutes later, they call me again and they made a mistake looking up the specs on the suspension and that it'd only cost and extra $20 ($50 at worst) for the camber. I figure that's not too bad so I told them to do it.
Then the car's ready to be picked up at around 3:30 PM. I ge there and they tell me that they did the camber and all the other stuff, but they found some other stuff that needs fixing. Remember a while ago I mentioned that the car looked a little front heavy, but everyone was saying that's a characteristic of FWD cars? Turns out the shocks and springs were bad and one of the subframe mounts might be worn. Not to mention I have an exhaust leak, need a tune-up, and the passenger side power window switch stopped working. Well, I'm mostly pissed at the shocks. I had them do the camber, which involved moving the struts about 1/2 inch. Now if I knew the suspension was worn, I would have waited to do the camber after I got them replaced. Now I gotta watch how hard I hit bumps so I don'd screw the suspension to the point of no return.
So the total came to $251. I was a little shocked. So, I'm planning to try to do my own tune-up next month. BTW, does anyone know what size socket I need to get the spark plugs out? The exhaust leak, I won't worry about since I haven't noticed anything and there's no emmissions inspections here. The power window switch I can grab at the junkyard. It's not too hard to replace. And the subframe mount, I won't worry about that since we use sand instead of salt on the roads. What was surprising was that I backed over a couple of parking islands, but the computer showed that the rear wheels were near perfect alignment. Go figure.
I was also washing my car this morning because my car was REALLY dirty (been driving down some dirt roads). There were some light scratches on the front fenders. That really pissed me off, but I guess that's a way of life. After all it is an older car so I shouldn't be so protective. I also noticed they got some sort of grease or oil on the passenger side front wheel and it just won't come off! I tried scrubbing with soapy water and it won't come off. I'll probably need to use something stronger. I love my car and I wouldn't want any other car, so I guess I'll live with the stuff I don't need to fix. I'm just a little ticked off right now from this experience.
