1 - 1 of 1 Posts
EDIT: I got it out and broke the rtainer. Back to the parts dept. Jim
I was able to fix the ignition switch actuator today. I had the cylinder out and when I put it all back together all worked well except ACC. So I took the cylinder back out and moved things around. I did not put the plastic piece in until I was sure everything was lined up. Now the cylinder will not come out. I think the piece above the gear and below the plastic may have turned. The car starts stops key comes out just no ACC. Should I just live with it? Thanks. Jim
1 - 1 of 1 Posts
