94clit Posted Today, 12:41 AM
" Goathead: what is your original problem? The coil could still be weak under load, with higher rpm's. Is there a spark leak anywhere?"
94clit,
The problem is what feels like random misfiring when the engine is under light lugging conditions/fairly low rpm. I refer to it as a "chuggle". At one point I thought it was TCC shudder, but the problem has gradually worsened and I can feel it when the TCC is not under lockup now as well.
I've been over the fuel system, EGR and ignition system with a fine tooth comb; everything checks out as being OK.
My timing light indicates a significant miss on cyl #3 when I rev the engine, but only slightly on other cylinders. I also get it when connected to the coil wire, which tells me the problem is at the coil or upstream from it. I might add that my light does this somewhat on my other car too (that one runs well!), but the fact that it's more prevalent on cyl #3 arouses my suspicion.
I have new wires, plugs, cap and rotor. I substituted a different #3 wire and coil wire; it didn't help. I tried a different distributor and ignition module; no difference.
Early on, I substituted a spare coil (which also passes resistance and visual examination), which didn't help. I suppose it's possible that both coils are weak and exhibited the exact symptoms, but it seems unlikely to me.
The problem doesn't seem to reveal itself (or at least, not very much) until the engine is warmed up. Perhaps I should try temporarily relocating the coil away from the heat of the engine to see if any difference is noted.
I do get an occasional DTC indicating a lean condition on bank #1 (where #3 cyl is located, by the way). I swapped the O2 sensors side to side to see if the DTC moves, but I'm still waiting for a code to reappear. The O2 sensors pass the propane torch test, although I suspect that is a very crude way of testing them. They have only about 15K miles on them.
It's probably some stupid simple thing that I've overlooked... I've been guilty of doing so in the past.
Regards... Mike
