· Registered
I have a '03 SE with a AM/FM Cassette in the dash. Can any of you audio buffs confirm that this will work.
I am adding a CD/Radio that will be in a remote location-it is not a Ford changer, it's a regular JVC unit.
Here's what I want to do-I want to tap the speaker wires just before they go into the factory tuner/amp in the trunk. I do understand that I will need to avoid having both radios on at the same time.
I know that the speaker wires are in the harness on the left side of the factory tuner as it sits in the trunk. But-there are more than 8 wires in that group...what do the other wires do? Could I pick up 12v power constant/switched and a ground back there also? If not...should I just plan on tapping the fuse box above and left of the brake pedal?
Thanks guys.
· Premium Member
For the ground you can just tie into the frame. The only switched 12v I know of back there is for the power antenna, but that is only on when the factory stereo is on. The only other wires back there are for the taillights, none of which are constant.
· Premium Member
I know the wire colours on the g3, not sure about the g4.
You cannot tap into the lines before the RCU, because the RCU in the back effectively *is* the radio and the amp.
If you want both your best bet is to get a CD changer.
· Registered
All I do before the RCU is get my switched power and constant power for the other head unit, then i straight wire everything else and bypass the factory radio. It is still plugged in so that i can use the climate control but i leave it off all the time.
· Premium Member
Ah, I see what you're saying. yes, you can do that, it'll work.
You may have to go with a bigger fuse in your panel though, depending on how much power the deck takes. But I got 2 amps remote wire connected to that so it should be okay.
