hey guys I changed out the IAC with a new one on my 3.0L Vulcan. Turns out the old one was a BWD model one that the PO's mechanic put in for them. Anyways, the new IAC helped but didnt solve the problem completely. When I shift into park it is still a little louder then i think it shoudl be with a new iac. I got out and watched the engine idle and it seems to slightly vibrate. like i can see the spark wires moving around alittle. Does this mean I have a vacum leak? I noticed the tube going to the oil filler, the rubber elbow, is loose like i can pull it off with out using pliers to remove the pretension clamp first. Is that normal or do you guys think I have a vacum leak some where else?
Thank you in advance, the stupid idle issue is almost fixed!
