1 - 20 of 58 Posts
Hello all.
So let me get right down to it. I don't know what engine I have in my car. Every time I go to an auto store im always getting the wrong parts for it because no one seems to know what engine is in it. My car is a 2004 Ford Taurus SE. Well... I believe it is an SE. I've had the vin decoded and some say its an SES. Here is the vin - 1FAFP55S14G163076.
The eight Digit is an S so that means Duratec DOHC right? But my engine doesn't have anything that says Duratec on it and it doesn't have the coils over the plugs. It has the 1 large coil and wires running to the plugs. Is this right? I cant find any other info so I figured I would ask. And is it an SE or an SES? If you need more info just ask!! Thanks!!
Yes you have a Duratec engine, and it's supposed to have the COP, not the single coil pack. Does your engine look like this?
It shows a BUILD date of 2004, but are you sure it's not a late build 2003? What is on the title(2003 or 2004)?
From Fordetis....... http://www.taurusclub.com/forum/124-taurus-sable-general-discussion/268417-obtaining-vehicle-build-information-oasis-etis-vin-decode-window-stickers.html
Primary Features
Build Date: 19.02.2004
Vehicle Line: Taurus/SableBody
Style: 4 Door Saloon
Version: TAURUS B VERSION
Engine: 3.0 V6 24V DOHC EFI Modular
Transmission: AX4NDrive: LHD FWD
Axle Ratio: 3.96 Final Drive Ratio
Emission: With 49 State/Non Green State Req
Air Conditioning: Manual Air Conditioning
Territory: (+)"USA"Paint: Ebony (Solid C/C)
Minor Features
  • Midnight Black Interior
  • (-) Version Packages
  • Less Fleet Related Items
  • Chicago Plant Build
  • U.S. Sales
  • Less Side Impact Package
  • SE Sport Sales Badge
  • Less Military Vehicles
  • Special Value Pack A
  • Less Ambient Temp/Speed Pack
  • Less Sales Feature - Level 1
  • NAAO Core Market
  • Job No.2 Program Control
  • With On-Board Diagnostic System
  • Less Premium Group
  • Less Special Language Label
  • Owner Hand Book Pack
  • Fixed Foot Pedals
  • Less Inter Cladding Surfaces
  • Front Floor Carpet Mats
  • Rear Floor Carpet Mats
  • With Illuminated Sunvisor - Drivers
  • With Illuminated Sunvisor-Passenger
  • Less Front Roof Grab Handle
  • With Rear Roof Grab Handle
  • Less Load Area Cover
  • Less Load Retention Net
  • Chrome-Plated
  • Less Roof Rack
  • Narrow B/Side Moulding-Body Colour
  • With Single Rear Wing Spoiler
  • With Dipping Rear View Mirror
  • With Drivers Power Mirror
  • With Passenger Power Convex Mirror
  • 4 Door Saloon
  • Less Front Seat Centre Armrest
  • With Split Fold-Down Rear Seat
  • Less Rear Seat Centre Armrest
  • Less Auxiliary Seats
  • With Driver 6 Way Pwr.Seat Adjuster
  • With Pass 2 Way Manual Seat Adjust
  • With Remote Controlled Tailgate Release
  • With Central Locking System
  • With Door Entry Remote Control Unit
  • Less Keyless Entry System
  • Less Rear Window Wiper/Washer
  • With Electric Slide Sunroof
  • Less Front License Plate Bracket
  • With Smart Drivers Airbag Restraint
  • With Smart Passngr Airbag Restraint
  • Spare Wheel - Mini Steel
  • 16 X 6" Alum Wheel 5 Spoke
  • Less Wheel Covers
  • Less Immersion Heater
  • With 49 State/Non Green State Req
  • With Standard Suspension
  • 3.96 Final Drive Ratio
  • 3.0 V6 24V DOHC EFI Modular
  • With Front Disc-Brake/Rr Drum Brake
  • 4 Wheel Anti-Lock Braking System
  • Less Anti-Spin Traction System
  • Floor Shift
  • With Single Fuel Tank
  • With Non Locking Fuel Cap
  • For Unleaded Fuel
  • With Tilt Steering Wheel
  • With Luxury Steering Wheel
  • With Speed Control
  • With MPH/KMH Speedometer
  • Less Outside Temp Thermometer
  • Less Anti-Theft Alarm
  • Electronic AM/FM Stereo Cassette
  • With CD Player Autochanger
  • With NAAO Radio Frequency
  • Fixed Radio Aerial
  • Less Upgraded Sound System
  • Less Telephone
  • Less Cigar Lighter
  • With Level 1 Headlamps
  • Less Daytime Running Lamps
  • Less Front Fog Lamps
  • With Dome Maplight
  • Tail lamps - Level 1
  • With Conventional Headlamp Control
  • Ebony (Solid C/C)
  • Less B&A Control Codes Issue 030388
  • Less B & A Control Codes (9270)
  • AX4N
  • Taurus/Sable
  • TAURUS B VERSION
  • (-)"NL"
  • (-)"CDN"
  • (-)"AUS"
  • (-)"RA"
  • (-)"GU"
  • (-)"BRN"
  • (-)"BZ"
  • (-)"ATG"
  • (-)"KOR"
  • (-)"AW"
Primary Features
Minor Features
  • U.S. Sales
  • NAAO Core Market
  • Fixed Foot Pedals
  • Chrome-Plated
  • Less Roof Rack
  • 4 Door Saloon
  • Less Wheel Covers
  • Floor Shift
  • For Unleaded Fuel
  • Less Telephone
  • Ebony (Solid C/C)
  • AX4N
  • Taurus/Sable
  • TAURUS B VERSION
  • (-)"NL"
  • (-)"CDN"
  • (-)"AUS"
  • (-)"RA"
  • (-)"GU"
  • (-)"BRN"
  • (-)"BZ"
  • (-)"ATG"
  • (-)"KOR"
  • (-)"AW"
No my engine does not look like that. It has the one coil and plug wires. I looked at my door and it says manufacture date is 02/04. My title says it is an 04. The title says it is an SES. But the trunk lid says SE. Maybe the trunk lid has been replaced? the car is black.
Then apparently the DOHC was replaced with an OHV
The DOHC is a better engine correct? Thats so weird. Why would someone install a worse engine? Maybe it was cheaper? And do you think its an SES or a SE?
A Vulcan is not necessarily "worse". They both have their pluses and minuses. The only thing that would make sense is that the previous owner had blown the Duratec and had a donor car with a good motor and swapped everything over. Without REALLY knowing what the PO did, it's all speculation. Out of curiosity, I would check to make sure the vin on the door sticker, the vin plate on the dash, the title all match. FordEtis says it's a SE Sport, aka SES. Trim level(SES, SE) doesn't make a difference when the engine doesn't match the vin. Take some pictures of the car and post them. This is interesting.
VIN swap is the more likely issue here.
I've seen this once before. The PO likely had the Duratec blow on him, and when shopping for a replacement engine found out that the Vulcan is cheaper to source by a decent margin, especially if you're shopping reman and not in junkyards. When you look for parts you need to make sure that you're getting parts for the 3.0 OHV, and NOT the DOHC.
Btw, I would check what the PCM shows as the VIN number, because that will most likely confirm if the swap was done at a dealer or on the cheap. If the PCM VIN doesnt match the one on the body, it can cause you to fail inspection by default in states like New York. And the computer will have been swapped with the engine since they're different between the two engines.
Discussion Starter #13
Where is the PCM at? I can look real quick and let you know what the vin is on it. sorry didnt mean to quote everyone on this!!
The catch code on the PCM should match the decal on the strut tower.
I'm not so sure. That door sticker looks like it's always been there. Not to mention it was 100% impossible to get a factory sunroof on a SE. Maybe there was some collision damage and the trunk lid was replaced at some point? Hard to say what foolery is going on here. It's also funny that it says "less keyless entry" but yet it came with a remote. ETIS is goofy like that sometimes. I've seen shady dealers "uprate" to a SEL before and charge more without actually adding any options, but never the reverse.
Discussion Starter #20
well, I don't have a scan tool so I guess we will never know about the vin in the PCM. And If the attached pic is the sticker on the shock tower you were referring to, it doesn't match any of the numbers on the PCM. Or at least the thing on the passenger firewall that I believe is the PCM.
1 - 20 of 58 Posts
About this Discussion
8 Participants
ice445
Full Forum Listing
