1 - 18 of 18 Posts
at least it will have a new home
Progress from night one.
PS for thoes of you who dont get it....im ripping the engine out.
are you swapping out the whole engine, or just the heads again?
Poor Baby sho... least your other car is getting a good strong heart in its heart transplant./.
Here is the progress from Night 2...had to chisel and drill out some tack welds, and removed the radiator
I feel left in the dark....what are you up to?
ripping the engine out of my totaled car.....needs to be moved to the new one cause its gor more duratec bling than the one thats in the new car.
if you dont understand, let me know and ill explain better
G
You're swapping out the SVT Contour heads right? How's that going to give you more power? PLEASE, PLEASE explain...I'm kinda mechanical illiterate. I can install a mean stereo though. Man, if I only knew mechanical AND electrical, I'd be set
The engine im pullin has svt heads and cams. Since the svt heads are designed for a 2.5l engine, the area insude the head is smaller. When put on a 3l engine, it bumps the compression ratio from 10:1 to 11.25:1 creating more power.
The svt heads also have extrude hone intake ports as well as the svt cams giving a more "agressive" timing (longer duration, etc.)
Brad
He's not just going to take the heads off his old car and put it in the new one...he's talking about switching whole engines. Which I would assume dropping the subframes and switching the whole front cradle out...correct me if I'm wrong, I'm not schooled in the ways of the DuraBling
G
Brad
Oh, I get it now...Thanks for the explination...How much extra hp do you expect to get?
Brad,
I thought you weren't going to do the swap until the fall? or did you decided to be an over achiever and tryign to atempt this feat yourself? without bob the garage god
G
Hey, I remember that engine!
And Brad, I still have the Durabling TypeR sticker on my toolbox, I think it's only fitting that BabySHO goes to the crusher with it.....
Discussion Starter #15
whole engine is getting moved with the tranny. Im gonna do the swap with bob, but i need to get the engine out to take it to him plus i got to get rid of the body from the car soon.
Brad
I'm sure you've already covered this somewhere else, but I'm lazy and don't feel like looking for the post...where did you get the clear corners for the Baby SHO???
JR
Discussion Starter #17
ebay or nopi.com
Brad
PS be careful....there are two kinds...the cheaper $18 ones that are "euro" style and the $25 that look factory only clear. Mine are the latter.
Brad
Yup, that front impact bar is a biatch to remove, after taking the bolts out me and my dad grabbed the crowbar and sledge, few hits and it was off
Glad you got another Bull to continue the legacy of this engine!!!!
1 - 18 of 18 Posts
