If you are able to help me I WILL pay You, I need this vehicle to go.
Hello I can not figure out what happened to my Taurus. The situation is My girlfriend was driving down the freeway going about 75mph, when her Upper radiator Hose busted. On a 3.0L V6 GL, Coolant went everywhere from her dist cap wires, air filter, everywhere on the driver side of engine. I taped up the hose added coolant but not full, on the road. Would not start. It would crank and try to start but wouldn't. I Pulled it off the free way. Oh yeah I think my girlfriend flooded it. Let it sit over night. still no start. Towed it to a garage where i replaced the plugs, wires, Dist cap and rotor. The dist cap i bought had the vent on the wrong side i don't think that would have anything thing to do with it????. Unless the rotor is not hitting the diodes not causing spark what do you think????
Still will not start. When pulling the old plugs found all plugs fouled and full of fuel and oil. Try to arch the new spark plugs there was no spark. Does anyone have any ideas what i could be doing wrong. People have said in that the fuel filter or pump could be bad, but would that be a coincidence that that would happen?
OK I have replaced the plugs, wires, Cap and rotor, and the ignition coil and my ecm under the distributor passed the test. I got the engine to start for a little bit but it fried the alternator. I have replace the alternator and the battery. But why wont the engine stay running. I am going to try the fuel pump cut off switch in the trunk, but if that doesn't work what could it be.
Well the emergency shut off button is pushed in so that can't be it. Oh yeah when i tried to light the old plugs they did not burn nor did they evaporate. I know that is is a little fuel and a little oil. Could the timing be off. When it runs for the short amount of time it sounds like the timing is off and i hear air blowing out. I can't figure it out. Can someone help?
I have More when the coolant hose burst. Is there a sensor or something that would cause the engine not to start due the low coolant.??? I do have very low coolant would that have anything to with not starting. I have done everything i can think of. Can someone out there help me.
These are some responses i have had in a different forum:
try the fuel cut-off switch in the trunk that shuts off the fuel to the engine during a jolt to the car,possibly during tow. Its a little box,usually on the left side there is a button that will pop out and needs to be pushed back in to bring fuel back to the engine
could be your multi function relay, aka the black box on radiator support,try to check toward firewall for wiring harness if it doesn't start but turns over it is the really box or that plug on toward the firewall on drivers side
If the fuel pump or fuel filter were bad, then the cylinders would not have been full/fouled with gas.
You were not pumping the gas when you were trying to start the car, were you? If you were, DON'T DO THAT.
You may have damaged the engine when the radiator hose burst. You need to make sure whether the liquid in the cylinders is fuel or coolant (bad head gasket.
First, carefully disconnect the electrical connectors from the fuel injectors, and dry out both the injector end and the electrical connectors on the wires.
Then, remove all of the spark plugs. Clean and dry all of them, and spinning the engine with the spark plugs out, for about 30 or 45 seconds to blow all of the liquid out.
Now put the spark plugs back in, try to start the engine. You should not need to pump the gas pedal. If the car starts, the problem was probably shorted fuel injectors due to moisture. If the car does not start, pull a spark plug and look for liquid shorting the center electrode to the side electrode. If you see this, that is why the car will not start. Light a match and see if the liquid burns or evaporates. If it burns, then you have a fuel injection system problem. If the liquid biols and evaporates, then the engine has one or more blown head gaskets, and you need to repair it, or replace it.
So if you have more input i would greatly appreceate it
Thank you
Scott & Shannon
Thank you
Scott & Shannon
