Hi . So just got a dash cam for the 02 Taurus and i need a 12v switched source to power on cam and the cig and extra port are full time on grrr. Any easy options as ill have to put a 12v socket end on it too hook up the cam
I am doing the same for my 2001 taurus. Same here... cig and extra port are full time on, so can not use. SO... i looked at the fuse box, under the driver dashboard, and found a couple of choices. Will find out tomorrow if they are "switched". Fuse #11 is for the rear washer & cellphone and #36 is for turn signals & back up lamps. Thinking either of these will work, as I think the ignition needs to be in ACC or ON, for these things to operate. Look at your 2002 user manual for fuses that seem simular. I think the 2001 and 2002 are the same. Here is a link photo, to the fuse box info.
215909
Going use an "add-a-circuit" like this, to tap into the fuse.
215913
Here are the fuse box diagrams and info......
215910
215911
215912
Hope this helps.
Maybe we can let each other know what one we decided on. Kerry
Thats cool I'll have too look into this weekend
.. it a shame the old school rides had at least 2 taps too plug into constant and a switched source ...
