1 - 20 of 58 Posts
It has a 3.0 v6. It's the overhead valve one. It had a bad miss about 5 minutes after starting it. I don't know if miss is the right word. It sounds like it is stumbling. It runs fine going down the road until I come to a stop. It will stall out sometimes. It always sounds terrible when it is stopped and idling. I cleaned the air idle valve as best as I could. Now it won't idle at all. I just took off the air idle valve and am letting it soak in some carb cleaner. I really didn't think the bad idle was the air idle valve. I was just throwing thing against the wall to see what stuck. I though it was more likely the throttle position sensor. Any ideas out there.
Pull codes even if the CEL isnt on. No scan tool needed for OBD1...... just a jumper wire and count the CEL flashes. Instructions all over the web on how do do this.
I did pull the codes ECT Engine coolant Sensor Out of range. I replaced it. IAT Sensor I replaced it Transmission temp Sensor. I haven't replaced it yet. The other codes it threw were 536 Park brake short. is what I found for it. 521 Power Steering pressure switch is what I found for it. I also tuned it up. New cap, rotor, plugs, and wires.
My 93 had an issue with stumbling and it turned out to be the silicon hose to the EGR flow sensor was cracked. It is a 3/8 inch hose located behind the intake. A friends 1990 had a bad IAC valve and it would not idle at all unless you held the gas pedal down a little.
I checked out the silicon hose to the EGR flow sensor and it's ok. Did I damage the Idle air control valve trying to clean it?
If you ran the codes without the engine being fully warmed up, you will always get a code for ECT and ACT/IAT and TFT out of range low.
Ok I'll warm it up and run the codes again. I replaced the iac. It runs again, but still has the stumble after 5 minutes of running. When I first start it it runs at a high idle then the idle lowers and the engine begins to stumble or miss. Rough idle. It dies when I come to a stop while driving. It fires right back up. IS the TFT transmission oil temperature sensor.
You need to look or listen for a vacuum leak that may be causing your stumble. I agree on the Motorcraft brand for newer Taurus but I had good luck with aftermarket IAC valves on my 1991 and 93.
Discussion Starter #13
Yeah the one I got was from a wrecking yard. I'm pretty poor. I don't know what's wrong with it. I can't aford to buy new parts that it doesn't need. I'm going to the wrecking yard tomorrow to get a throttle position sensor.
Usually the position sensor won't cause that sort of issue. On my 91 it caused a dead spot in the acceleration that was repeatable. You can check it with a ohm meter for smooth change.
^^^^ +1
Use a DMM in DC Volts hooked to the black and green TPS wires. Turn key to RUN. closed throttle voltage should be under 1.0 V, and should increase linearly (no spikes / dropouts) to 4.5 to 4.8 V at WOT. If it passes this test, TPS is not the issue.
As noted above, I would suspect a vac leak.
Discussion Starter #18
This is something I should have added to begin with. About a year ago my car broke down driving down the road. It just died. My aunt put it in the shop. They put a re-manufactured computer in it from China. My aunt drove it about a mile and it died again. The shop put another computer from China in it and it's had the stumble and dying at stops ever since. I got the car from her about a month ago. Does anyone think that maybe China sent a computer for a different model Taurus or maybe it's a bad computer? If so where is the computer located, so I can go to a wrecking yard and get one.
Could be. Find a used PCM locally or check Ebay. 3 letter/number code (like A9L, A9P, LA3, 8UA etc) on the sticker on a PCM you find must match the code on the current PCM, assuming the correct PCM was installed by the shop.
1 - 20 of 58 Posts
