Weil I looked into this code as much as I could, but that wasn't enough tech told me it wasn't my tranny it was the programing sombody had done to it. After a good flash and restore for for dealership $750 it still didn't fix the issue. The tech asures me its not the transmissions fault its the pcm witch is assyted by the tach with dosnt work right. It wil work some days and others it pegs out and will than read backwards, he than tels me it might be a short in the pcm or the harness.
Now if the crank pos. Sensor was not working the car shouldn't start or if it did it would miss fire, we just a lil note my sho gets down and buggies. Shifts perfect and all it gets bad gas milage mabey 12 miles to the gallon and some times after driving it when I put it in park it revs up to 2 grand or so. You can fell the stuttering when it his overdrive and trys to lock in. But if i hit theb od shitch it still stutters......... what the he is going on here anybody gotta idea
