If I want the guys at Circuit City to install my head unit and have it use the stock amps to power the door speakers and the amp what do I need to provide them?
I asked about it and their first response was that they won't be able to hook it all up without complex re-wiring that they don't want to do because of liability.
What exactly do I need to give them to be able to hook up the new HU to both existing amps.
IF this is possible.
Okay, so when CC guys install everything they will most likely go directly from the HU to the speakers and if I want to add any additional subs afterwards I need to use the rca jacks like a typical set up, right?
Can the stock amps be modified to be used with an aftermarket HU? I want to use a 6" in the back dash again but don't have the $ to get a new amp.
Thanks, worth looking into. Maybe someone else reading this can confirm this or not. I just don't want the CC guys to go in and hack everything apart if some of it can be salvaged.
If you had diagrams for the stock amp, I'd know. See the other thread.
