1999 Taurus SE Wagon (dohc, ax4n)
How to reprogram. Switch and key on 98 Ford taurus
What switch are you talking about? Are you talking about the remote entry key fob?
You can find instructions for programming the remote, and they all have to be done at the same time, here:
If you are adding a third key, that website also has instructions for programming keys. You would need both functioning keys to do that. If you only have one then you can program your keys using a free program called FORScan. You will need an OBD-II connector (usually you can get the Bluetooth ones) and a computer that will be close enough to connect. The instructions are in the software. You can do a search in these forums for the software and find the links for it.
