Hi guys, I just refilled A/C on my 2000 Taurus and I had found that low pressure valve is leaking. I can hear hissing sound and I'm positive valve is the reason why my A/C doesn't work just 2 days after refill. Is there any way to replace the valve or have something put on the valve to prevent leaking?
Thanks,
Klikerko
If you mean cycle switch on top of accumulator, you just unscrew it and screw new one. There is a valve in accumulator (similar to one in charging port), what should prevent freon leakage.
Hi Alex, I need to change valve on charging connector. Looks like it's welded and cannot be replaced. I think I will have to find some creative way to prevent leaking.
I just changed both mine. I ordered a tool off internet but not here for 4 weeks they say. So.........I put bolt in vice, took zipcut blade and made slice down middle of bolt, then drilled a hole in middle of bolt because spring goes down middle of tool.
I got both valves out, low side and high.
Could not find any tools to get job done, so made my own.
I got it Roof, thanks... So it is possible to remove valve like that. I guess you used same tool to put new valve back in place? Where did you bought replacement valves?
I had the same problem with my 1997 Taurus. The valve has a rubber ball so you can't just change the core. The whole valve can be easily taken off by a wrench. Ford part number for the valve is F3AZ19E762B.
Thanks daxia,
For now I improvised something on the valve with peace of rubber tubing and hose clamps. That stopped leaking and AC is working for a week now. I will leave it as is until leaks again.
