1 - 10 of 10 Posts
I recently bought a GEM from a junk yard but found out I actually needed the entire fuse box. They told me that's something I'll need to pull myself. Problem is, I have no idea how to do that. Anyone able to walk me through it?
Click on the Topic Finder at the top of this page and scroll way down to Electrical, then to: GEM, Fuse Panel, SJB Removal by thesavo. Good luck.
From Ford:
Fuse Junction Panel
Removal and Installation
1. Disconnect battery ground cable (14301). Refer to «Section 14-01».
2. Loosen bolts retaining three wiring connectors to LH side of fuse junction panel (14A067) and remove three connectors.
3. Remove two nuts retaining fuse junction panel to dash panel.
Item Part Number Description
1 14A005 Body Main Wiring
2 -- Bolt (Part of 14A005)
3 14401 Main Wiring To Instrument Panel
4 14A068 Fuse Junction Panel
5 14290 Headlamp Dash Panel Junction WireTo
Engine Compartment
6 14B205 Generic Electronic Module
7 -- Nut (Part of 14A067)
A -- Tighten to 4-6 N-m (35-53 Lb-In)
4. Pull upper ears of fuse junction panel down out of retaining bracket.
5. Turn fuse junction panel over. Remove screw retaining generic electronic module to fuse junction panel.
6. Unplug and remove generic electronic module from fuse junction panel.
1 14B205 Generic Electronic Module
2 -- Mounting Ear (Part of 14A068)
3 14A067 Fuse Junction Panel
4 -- Screw (Part of 14A067)
5 -- Generic Electronic Module-to-Fuse
Junction Panel Electrical Connector
A -- Tighten to 1-2 N-m (9-18 Lb-In)
7. Remove fuse junction panel from vehicle.
8. To install, reverse Removal procedure. Tighten generic electronic module retaining screw to 1-2 N-m (9-18 lb-in). Tighten electrical connector to fuse junction panel bolts to 4-6 N-m (35-53 lb-in). Tighten mounting nuts for fuse junction panel to 4-6 N-m (35-53 lb-in).
Ford forgot about all the stuff in the way. lol. Nice find. Thanks for posting!
From Ford:
Fuse Junction Panel
Engine Compartment
Can I just take those 2 nuts off and remove everything to get the code for keyless entry.
thanks for your time
You should be able to see the keyless entry code without removing anything. Try using a small mirror to look for it.
Do you think its on the top of the modular or on the side not sure where to look.
PS I have a service manuals but don't say much. Does Ford make a parts manual?
thanks for your quick reply.
No luck paper gone and no emboss numbers either so I guess out of luck hu
Can I use a scan tool to find the OEM 3 numbers.
thanks for any help
1 - 10 of 10 Posts
About this Discussion
6 Participants
cobrahd1999
Full Forum Listing
