The manual says turn to START and push the release pin. My problem is I cannot feel any kind of release pin when I insert a small torx screw driver. Anyone with experience please advise. Thanks.
What I needed was a paper clip (larger one) straightened. Torx bit was way too thick. When it got into the right hole, I got the springy feel. Thanks.
The only relevant part of that video is about pushing a retaining pin. Ford lock cylinders are removed with the key in Run, pushing a pin up from the bottom. Most do not require removal of any plastic.
