what year vehicle do you have?
edit: nvm, i looked at yoru profile, you have a '98 correct?
yes, you have to remove the headlights, and the three bolts across the top of the bumper (between the headlights). then under the headlights, youll see somethign that looks like a tab with a bolt in it, remove that bolt and the bolt underneath that goes into the body (same for both sides). finally, get on the ground and disconnect the bumper cover from the splash guard (plastic underneath front) by unscrewing any bolts (theyre small) that are there. hope that helps, if you have any more questions, ask... although you prolly should have used the 'search' function to begin with anyway
