how would i go about removing the rear seats to run power wire under in my 2007 ford taurus Se, in my 2005, my seats just fold down and i see the 4 bolts to dissasseble, but in my 2007 se, the seats dont fold down
On the bottom part of the seat (where your legs swing over) press in on the edge either on the corners or in the middle and lift up. The bottom should then be easily removed. Since your seatback doesn't fold I think there are two bolts that will be exposed when you pull out the bottom. Remove those then lift up and pull to remove the back.
