I learned from this forum that Taurus/sable transmissions are prone to fluid overheating.
There is ATX fluid sensor inside the transmissin case, which is supposed to be connected
to the ECU (computer control unit), I believe. Does any guy know how to read the temperature
directly from this sensor, or from the ECU unit? so that we can know exactly what's going on
in the fluid before it is burnt.
If the fluid really gets burnt, is it going to ignite the 'check engine light' on the panel?
I'm pretty sure the failure of my last transmission is somewhat related to burnt fluid,
but the CEL was not ignited in that case.
