I need to pull my old EATC out of my 1990 Mercury Sable 3.8. How do I pull the trim surrounding it without ruining the dash? I know it is held with clips, but am having problems with pulling the upper part. Any suggestions?
Does that not use DIN keys?
IT should be that you use the keys to remove the unit, then you can remove the trim, no?
I would try to get out the parts that aren't held in with clips first, and then try to use a screwdriver to gently pry the stubborn parts next to the already loose parts. (Don't forget to take off the knee guard and to take the screws out from behind it and above the cluster.)
QUOTE (Qwertz9586 @ Nov 10 2009, 01:47 AM) index.php?act=findpost&pid=765917
QUOTE (thesavo @ Nov 9 2009, 06:16 PM) index.php?act=findpost&pid=765863
IT should be that you use the keys to remove the unit, then you can remove the trim, no?[/b]
No, it is bolted behind a bezel:
Dash bezel removal is similar to other '90/'91 Taurus:
http://www.taurusclub.com/wiki/index.php/1...Cluster_Removal
Once that's out of the way, the bolts that hold the EATC in should become obvious.
Thanks for the reply. I went to a wrecking yard yesterday just for practice pulling the bezel, going into it blind. I am new to this so I didn't want to destroy my own dash. I did notice the EATC is bolted in, but I have never seen screws like that before. Since I have just a few basic tools, do you have any idea what type of tool I need to remove these?
About this Discussion
4 Participants
krg15
Full Forum Listing
