1 - 10 of 10 Posts
If it is like the Gen3 SHO which it seems to be it is under the bracket attached to the side. It took a while but I got it. I think it is 2 bolts.
I did it from up top with 1/4 in drive wratchet about a 6 inch extension and a 10mm socket. There is JUST enough room to get to the bolts that way.
Always wondered how that f***er came off. Keep us posted how it goes.
Thank you all so much.
I cant get the bracket off but I fix the hose.
I put the hose in place and use wrench instead a screw driver to tight the bolt.
So the total loss are 5 bottle of transmission fluid cost me about 20 bucks way less of 2000 which I thought it would be.
Thank you all.
1 - 10 of 10 Posts
