Yippee Ki Yay Mother [email protected]#%$!!!!
200K MILES….Original Tranny and Engine
(But I have a leak in my timing cover and she also burns some oil)
How I did it
· Perform maintenance according to manual up to 100K
· After 100K change tranny fluid every 30K
· Front Brakes/Rotors are pathetic on this car but buy Brakes and Rotors from Autzone and you can exchange them within 2 years so change them before year 2 and get a new set of rotors and pads
· Use OEM parts whenever possible there is a difference when it come to fit and performance
*non oem tension pulley-failed within year
*non oem tie rod ends, stabilizer links etc high failure rate MOOG/OEM are great
* yes it happened to me Bosch plugs failed within 20K
* non oem PS pump leaked within year
· Change the 3 or 4 vacuum lines for the intake at 100K and thermostat. Save yourself some aggravation down the road
· Change upper and lower IM gaskets when changing plugs
· BUY THE RIGHT TOOLS!!!!!!
· Wash the car once a month
· Quick struts are great
· Buy a service manual, search the forums, and google google google
· If you’re not mechanic by trade like me, man up your gunna make mistakes but be patient, plan your work and work you plan
· Change brake fluid, ps fuild, antifreeze at 100K and after that every 50
· DOHC engine mounts and tranny mount replacement are hard and so is the Oil Pan Gasket replacement but I did them so anyone can do them!!!
· The door panel leather that falls off take it to an a car upholster they will fix it for 25 each
· When your replacing the struts take the whole knuckle to a mechanic/machine shop and have him remove and replace the ball joints. Dirt cheap and stress free
· Sometimes you really just need a bigger hammer especially for those damn rear drums
· Buy a torque wrench
· BUY A TOYOTA!!! J j/K
THANK YOU EVERYONE WHO HELPED ME ALONG THE WAY IN THIS FORUM!!!!
Talk again @ 250k!!!
How I did it
