Where is the TCC actuator connector located? I wish to disable it for test drive purposes, and my manual isn't helping me.
Regards... Mike
The solenoid itself is on the valve body - you'd have to get the side pan off to unplug it. However, if you can locate a wiring diagram for the big connector on the tranny, you could probably find which wire to pull out to disable it. I just can't look up wiring diagrams for cars that old thru the ford site. Sorry.
Nidan,
Dang! I wanted this to be unplug-and-play!
I may be able to obtain wiring info from a friend.
I appreciate the advice.
Regards... Mike
