1 - 12 of 12 Posts
The shop says the cats are shot and the muffler is full of debris.....I want to call BS but how can I be sure?
I did have a dead coil assy on one of the cylinders. Replaced it this evening and the car runs better, but the muffler does sound weird.
Codes where for two packs (E and F)...
with the engine off and cold. tap on the muffler with a rubber mallet and listen for a rattle. kinda sounds like change shaking in ur pocket. if you hear it then its possible that its full of crap. then let the car run for 15 to 20 mins. turn it off and look at the cat. if the cat is red then yeah its bad. if you had a bad coil then the gas wasnt getting burned off and got dumped into the cat. it will clog the cat depending on how long it was bad. the smell of gas should come out the tail pipe till the cat gets hot enough. after that the smell should be almost gone. if the smell is still strong after 20 to 30 mins of running then the cat is clogged up.
If you have been running around with a misfire or failing coil, it will melt the cats. You will need to do the checks, but I think your shop was right on the money.
^^^^ +1
Bad missfire for too long a time = melted cats = big $$. NEVER ignore a missfire code.
1 - 12 of 12 Posts
