1 - 9 of 9 Posts
I put the entire bottle of viagra on the auxillary seat of my 97 wagon and I still can't get it up. :( What am I doing wrong? :huh:
Now, on a more serious note: This may sound like a dumb newbie question, but how do I unfold the auxillary seat on my 97 wagon? The back panel of the subfloor cargo area flips up such that I can see the auxillary seat cushions, but I can't get the seat to come up. There must be a release that I haven't found yet. Where is it? :blink:
Sounds like a question only your doctor can answer. :lol:
Isn't there a strap that doubles as a release or something on those seats?
Originally posted by felony@Oct 20 2004, 12:31 AM
For my 91 GL look at the rear left and side wall of the cargo hold. Has a black pull lever.
The only thing that I can see in the cargo hold that looks like it might be a lever, is at the left of the forward edge of the auxillary seat unit. There are, what appears to be, three holes in the floor along the forward edge. The ones in the middle and on the right are covered by black plastic plugs. The one on the left is open and has a short tab that moves a little when I press on it, but it does not seem to release the seat. Is there some place I have to press or pull on the seat to make it pop up? :unsure: :blink:
I'll take some pics of mine tonight when I get home...it'll be stuck if it hasn't moved in a while
after you get the seat flipped up use the lever on the left side(recessed) work that up and down a few times in case it's stuck...while lifting up the seat at the same time, if you look in the hole between the back and the base you'll see the spring/hinge combo that will release it...
Racer X Posted on Today at 8:15 am
Got pics?
Alot of innuendo in here! :blink:
Discussion Starter · #9 ·
Thanks, I found the right lever and everything comes up now. Don't work worth a damn if your pullin' on the wrong part. Guess I can take the viagra back to the pharmacy. :D :lol2:
1 - 9 of 9 Posts
