I need to remove the washer or shim on my a/c compressor and I am wondering what the best method of doing this is? Can someone share what tricks they have learned? Thanks
You have to do it from the bottom of the engine bay. Remove the plastic shield and the compressor bolts. The nose of the compressor will face down so you can remove the snap ring and get to the shims.
How do you know the shim needs to come out?[/b]
Do I need to drop the subframe, like I see a lot of Vulcan guys doing?
QUOTE (Blacksable @ May 29 2009, 11:20 AM) index.php?act=findpost&pid=728844
[/b][/quote]You have to do it from the bottom of the engine bay. Remove the plastic shield and the compressor bolts. The nose of the compressor will face down so you can remove the snap ring and get to the shims.
