1 - 12 of 12 Posts
Haven't seen anything like that. But I am not a mechanic and know only about my cars. Apparently, the plastic/rubber hose deteriorated from age and heat. Shouldn't be but not unexpected. As sheila said, the rubber hoses you can buy at auto parts stores are rated for automotive temps and should be okay.
I also noticed a bit of smoke (like what comes out of this hose) coming from the left side of the back valve cover area.
The hose in the video is your 'crankcase breather hose'...it works in conjunction with the PCV valve (which is what you may be referring to at the left side of the rear valve cover emitting the smoke) to flow air through the engine, removing harmful gases that get built up from the hot oil and pressure, then safely burn them in the in the combustion chamber and exit them out through the exhaust....I think? :dunno:
The hose didnt actually "melt", it just detererated from engine heat and oil vapors in it. VERY common problem.
I am surprised to hear it is a very common problem. There are plenty of plastics that can withstand engine heat/oxygen/oil more than 10 years. Such technology existed back in the 90's. Ford knowingly chose an inferior material to save cost.
1 - 12 of 12 Posts
