My horns quit working yesterday and the CC never worked. I did some proble diagnosis and discovered that the horns and relay were ok. I know this because I accessed the grey connector at the right of the steering column and grounded out the yellow.lt green wire and the horns blare.
This tells me that the problem is somewhere in the steering wheel/column. So, as I have never taken the horn pad out of a Ford, I did a little reading in my trusty rusty Haynes manual. To replace the horn switches, it says to remove the 2 screws on the back of the horn pad and it comes right out. However, the next topic that they list is replacing the cc switches. In this, they say to take the car to a dealer to have the horn pad removed, due to there being an air bag underneath it. As this is obviously 2 contrary instructions, I don't want to proceed until I am sure of what I am doing.
So, do i just remove the negative battery connection, wait a couple of minutes and then remove the horn pad? f this is the right way to do it, what problems am I likely to have with the air bag, such as spilling out all over the floor in a big heap, etc.
I suspect either bad wiring or the clock spring is shot. If it si the clock spring, i thought of just wiring a momentary on switch to the yellow/light green wire going to the horn relay and then connnecting this switch to ground. The schematic for this part of the wiring (horn and cc) is unclear in the Haynes manual. Will it cause any unforeseen problems if i do this?
