1 - 11 of 11 Posts
hey all i got a 2000 SEL and still have a stock radio in it. I also have a seperate satelite radio that i would like to hok up and a ipod touch. is it possible for me to hook up a AUX port to the radio, or am i stuck using the tape deck?
Do you have a CD Changer? If so, do you want to continue to use it?
QUOTE (Bull Geek @ May 20 2009, 07:03 PM) index.php?act=findpost&pid=726783
Do you have a CD Changer? If so, do you want to continue to use it?[/b]
:werd:
There are things out there that just plug in to solve your issue, just need to know what your setup and needs are.
QUOTE (Parker811 @ May 20 2009, 08:47 PM) index.php?act=findpost&pid=726847
QUOTE (00tec-saTX @ May 20 2009, 11:29 PM) index.php?act=findpost&pid=726836
http://www.crutchfield.com/p_469FRDRAUX/Pr...AUX.html?tp=422
Will replace your CD changer and make it an Aux input when you press the CD button on the head unit. If you reinstall the CD changer, you need a PIE X3 instead.[/b]
so my stock radio has a port on the back of it for the adapter to plug into?
It plugs into the RCU in the trunk where your cd changer was.
The tape deck mod uses an input that is never used & only requires splicing into a few wires on the harness. I did it on my 2005 SEL (you can see the pics in my sig) It does not cost anything, does not use the 6 disc changer input, and sounds perfect.
1 - 11 of 11 Posts
