1 - 2 of 2 Posts
I am stuck in a situation as of now,my car battery went dead,im an attempt to boost the car we locked the keys in the bloody car,and my keyless will not work because the battery is dead.
I am under the car and i cannot see the lock,or cable?? Where is it,and what is the easiest way to manually un lock the hood latch...? I really need to get my car keys out,so i figured i will put a battery in and then use the keyless..Anybody able to help?
Thanks
You can crawl under the car and put a positive jumper on the starter where the big wire attaches. Put the negative anywhere that makes a fair ground.
Hook the jumpers to your best source of 12VDC.
You should have enough power to pop the locks now.
1 - 2 of 2 Posts
